2 ?'s 1 vacuum, 1 tps
Car: 91 z28
Engine: 350 stealthram
first ?. if you've been running your car and shut it off when u pull a vacuum line off should it suck air? second? i checked by ohms on my tps between a and c. ihave 12.8 when the meter is at 20k. is this too high and is it causing any complications .no codes.
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
First question: No, after shutting off the engine, you should have no vacuum left in the motor (brake booster, yes..)
TPS: No clue, five7 will know.
Any reason for checking these things? Perhaps if you give the problem we can give you other things to check...
Car: 1982 Trans-Am
doubt it.
Do your brakes work?
If so, why are you pulling it off?
Does the car run funny? high idle? What's the vacuum reading at idle?
Is the idle speed "hunting"?
Car: 91 z28
yes my brakes work but have been troubleshooting bad vacuum connections and am pulling the line off to see if its sucking air somwhere else. car was hunting but just got it to stop. cleaned iac and replace some hoses and now its running better but im curios to now if its sucking air somewhere.
Car: 1982 Trans-Am
ok!
Now we're getting somewhere. I had to pry some info to help ya.
Well if it's working ok now, are you still planning on checking other things?
Hearing any whistling?
What induction is this? carb? FI? EDIT: ok, stealthram = tpi Nevermind...
What's vacuum level at idle?
You could try the good ol' propane trick to see if it's pulling in air somewhere that's subtle...
Another one is to pull a hose, and if the idle gets worse, then that line was ok, if it doesn't change, then that line had/has a leak.(sounds like you're doing that already...)
Car: 91 z28
drove the car today for an hour. run better then it ever has ran before . idles smoothly. i believe it was a misadjusted tps voltage. but now i get a good a/f mixture at idle part throttle antdwot ,even in od at 70 mph.i also swapped out 90% vacuum hoses.
Pac J
05-17-2020 10:44 AM
HoosierinWA
10-07-2015 10:15 AM
