Pulling TPI engine with accessories,where do I hook up the chains?
Pretty much same as title.I'm swapping my TBI engine for a 91Z TPI engine,The throttle body engine is out,but where can I hook the chains to pull the TPI engine with all the accessories still on it?
www.tpis.com sells a tool called the "happy hooker" for engine swaps of all sorts, I would look into that. it seems to be a good design.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
thanks,reason I was asking is a have an engine leveler that makes it easy to swap motors but this is the first TPI motor swap i've actually done and you cant get to the intake bolts to hook it up and the chains aren't long enough to hook up anywhere else.Looks like i'll be using the single chain method...i just don't want to risk messing any accessories up.
The_Phoenix
09-03-2015 10:56 PM
R3500
08-17-2015 12:16 PM
Sanjay
08-12-2015 03:41 PM
