I can't believe it! Has this ever happen to anybody?
Car: 1991 Formula
Engine: 5.0 TPI
My stupid alternator broke, literally!
I can’t effin believe it! The stupid thing cracked in between the mounts and broke off taking a piece of the alternator/PS pump bracket along with it!
Good thing I was only on the entrance ramp to the highway.
Just think, it’s been almost a year since I’ve seen my mechanic.
I think I’m going to put XX amount of days since last towed on the rear window.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
u mean the case on the alternater littlerly snapped? Take some pics I'd like to see! Never heard that 1 b4
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I had a generator break on the '57 a couple of decades ago. Does that count?
Want to see a broken mechanical fuel pump housing?
Car: '82 Z28
The housing on my old alt busted... but that's because I threw it on the ground The new one is so much better than the old one ever was.
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
I've had a CS-144 (high output, bigger diameter case) alternator break off (actually, the extension bracket that bolts in place of a CS-130 broke). Now I always run the alternator support brace that goes to the back..
Car: 2000 Trans Am WS6 (Black)
I had a 105 from autozone that the part of the casing that holds one of the bolts, along with about half of the outer casing just ripped from the rest of the alternator.
I just put it in the box the other direction and used it as a core charge.
CHA-CHING
how the hell does an alternator casing BREAK? only thing I can think of is that it was 'freezing' up and applying a strong force to the mounting area on the casing, causing it to break off.
CHA-CHING
RedLeader289
05-28-2019 01:47 PM
