ZZ4 stud girdle
Car: 88 Firebird
Engine: 302 SBC
Axle/Gears: 4.27 Dana 44
ZZ4 stud girdle
Has anyone found a stud girdle for the ZZ4 heads? I understand they have a different stud spacing.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
ZZ4 heads are no different, stud-wise, than the corvette "113" castings, considering that is what they are based on.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
You can't run a normal girdle with the centerbolt valve covers - unless you know someone who can get you LT1 factory race car parts. You need to go 7/16" studs like I did for more stability.
New2Chevy
09-28-2015 12:35 AM
355tpipickup
09-13-2015 11:35 PM
