The perfect 2 piece rear main seal install
Car: 86 Camaro Iroc-Z
Engine: 355 TPI
I am wondering what I can do to install my 2 piece rear main seal to minimize the possibility of a leak.
What can be done to make it a perfect seal? I've install 1-piece seals with no leaks but the fact this has two makes me think it’s a lot easier to leak.
Whets your secret to minimize leaking....
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
convert to 1 peice rear main seal
seriously though, i don't think a trick, just install it and hope for the best
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Make sure you rotate the seal slightly in the block so that the ends of the seal don't line up with the mating surfaces of the cap and block.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
1 peice pan gasket abd your done, no worries.
1992 Trans Am
05-10-2023 07:19 PM
engine, hope, install, installation, installing, main, piece, rear, sbc, seal, seals, t5, thoughts, transmission, tricks
