what would make my car unstable at high speeds???
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
i was going fast yesterday like 65-70 and my car was hard to keep under control. it felt like it was hard to keep strait and didn't feel tight like it usually is. also i have a feeling this has to do with the clunking sound that is under my car when i go on bumpy roads.any one have any ideas? also struts are like a year old. could it be balljoints or tierods? what are the symptons of both when they need to be replaced?
I understand that the idler arm is a "weak link" in f-bodies. Get underneath the car and wiggle all the steering components. Then you'll find the loose culprit. No pun intended....LOL
[This message has been edited by a73camaro (edited September 05, 2001).]
Car: 92 Z28 Z03
what are the signs of a bad ideler arm? also the clucking sounds comes from the passange side and only happens on bumpy roads. but ill check that out
thanx
thanx
Car: 1989 Pontiac GTA Hardtop.
Engine: ZZ4 - 350
Transmission: Garbage
How about bad balance on tires, or just bad tires?? It could be a lot of things. Good luck man.
Mike
Check out My Car Pics http://albums.photo.epson.com/j/Albu...667&a=13599419
Gran Turismo Americano "The Ultimate Firebird"
Smokin 1989 GTA- Bone stock except for exhaust. (no catalytic-stainless pipe into Flowmaster 2 chamber) & AC Delco Rapid Fire Plugs
Mike
Car: 92 Z28 Z03
i think it has something to do with my sway bar because it also makes like a cluking sound and i heard the bushing can make a sound if worn
Linson
08-21-2015 02:12 PM
