I got a sound not allowing me to run car
Ok this might be kinda long. I redlined my car in 2nd gear(5spd.,TPI for reference)and then it died. I didn't go past red line it died while i was shifting. But now i got a wierd clanking sound on the passenger side of my block when i start the car. It will stay started for a while then it will die w/ no oil pressure. i pulled the valve cover and checked to see if i had collapsed a lifter, and all the valves were lifting. Could i have a bent rod, or something and how would i check with out having to rip apart anythign unless i have to. Thanks a lot in advance.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You may have thrown a rod. Check the oil for metal shavings. You also could have spun a bearing, but I wouldnt think it would make a loud clanking noise. I think something is definitely messed up bad though.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
"Ponies can run, but birds can fly..."
1983 Firebird
TH700R4 Auto
Small Block 400
Car: 4
Engine: 6
Transmission: 5
Sounds like it spun a rod bearing. That's a fairly terminal engine illness. Pull off the oil filter, pour out the oil into a clear glass jar or something like that and see if there's any metal particles in it; if there are, then your motor has gone to the big motor home in the sky.
ICON Motorsports
ICON Motorsports
could he of floated a valve, and as he said, possible bent a rod? thats the only good thing about those dang imports. 9000+ RPMs on a stock GSR
- David
88' GTA 350 MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT
- David
