Timing Not Advancing
Why is my timing only being advanced 16*?
Its an L98 and the base timing is set at 4* BTDC. I brought the rpm's up to about 3000 and it was only advancing 16*. I tried with the brown wire unconnected and then with it connected but still the same result.
Please help.
Bob
350 TPI, 700R4(rebuilt), K&N's, MSD 6AL, Headers, Flowmaster, 160* stat, airfoil, MAF screens cut out. 13.88 @ 101.18 mph
Please help.
Bob
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
did your clear the ecm trouble codes. since you said that you ran the engine with EST bypass disconnected you could have set a trouble code. 38* of advance sounds about right.
[This message has been edited by mystikkal_69 (edited September 05, 2001).]
nhra-trans-am
Southern California Area
09-17-2015 10:16 PM
