Will a tire change effect my speedometer, if so by how much?
Car: 1991 RS and 1998 Trans Am
Engine: 305(lo3) 346(ls1)
Transmission: 700r4 4L60e
My car had 225/60/16's on it, I put 245/50/16's on it. Will this throw off my speedometer reading? If so how much, and how can I fix it?
Thanks,
Brad
91 metallic blue RS Flowmaster exhaust, Eibach Sportline Springs, Open element, 323 posi rear w/ 4 wheel discs. 350 comming soon.
Thanks,
Brad
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You'll be going from a 26.6" tall tire to a 25.6" tall tire.
Your speedometer will be going faster than you actually are going.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z SuperPro ET Bracket Race Car
461 naturally aspirated Big Block
Best ET on a time slip: 11.242 altitude corrected to 10.89
Best MPH on a time slip: 121.52 altitude corrected to 125.89
Altitude corrected rear wheel HP: 497.9
Best 60 foot: 1.546
Racing at 3500 feet elevation with a typical race day over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.546
1 Post
Car: 99 Formula
Axle/Gears: 342
This will affect your odometer as well.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
3" Hooker CatBack w/Aero Chamber muffler
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4
B&M Megashifter, 5" Autometer Tach w/shift lite
'86 IROC
GM GOODWRENCH 350
KN AIRFILTER
160* Stat
3:73 Posi
Rebuilt 700R4
Car: 1988 Trans Am GTA
Engine: 5.0 TPI
Transmission: TH700-R4
Go to this site for a Tire Calculator
http://www.intercotire.com/calculators.htm
First check the diameter of the tire by using the calculator on the link: "Metric Tire"
Then use those diameter numbers on calculator in the "True MPH" page. You have to plug in the spedometer reading before you calculate to get the actual MPH.
Take a look at it.
Take a look at it.
Thanks for the help. Ozzy88gta that link was just what i needed. According to the calculator my speedometer is off 2-3 mph depending on the speed. Is there anyway to correct this?
Car: 4
Engine: 6
Transmission: 5
Well, you went from the wrong size of tire, for which the car's speedo system was not designed, to the stock size. So what's to fix? By doing that, you should be fixing what was previously broken.
Regardless, the smart thing to do is to drive down a section of freeway or something like that with mile markers; and compare your odometer to the measured mileage. Use a good long stretch of road like 10 miles at least. It's easier to measure error in the distance than the speed.
ICON Motorsports
ICON Motorsports
I'll give the milage idea a try. However didn't the RS's w/ 16 inch wheels come stock w/ 235/55/16 tires? The 225/60's were put on by the previous owner, but either way (60 or 50 series) the tires would be 1/2 inch different from the stock height of 55. I guess the 2-3 MPH doesn't really matter, i can learn to live w/ it, and i don't plan on selling this car. I'll still try the milage test though.
thanks,
brad
thanks,
brad
ambainb
04-25-2016 09:21 PM
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
