Max lift with AFR heads?
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
...does anyone know the most lift AFR 190 heads can handle (out of the box from AFR)....I'm gonna do a cam swap...thinking about the GM847 or a little bigger and think I might have to swap springs.
Thanks! 350Z
Thanks! 350Z
1 Post
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
your heads more than likely have come with the 8020 1.450 springs.
1.450" OD Hydraulic Dual Valve Spring, 120 lbs. on seat, .550" maximum lift, AFR #8020
i wouldn't recommend running those springs with an 847.
Car: 89 Iroc
Engine: L9-to small
Transmission: 6 spd
...thanks man....will any valve spring for sb chevy work or do these heads require anything special....I'll prolly order them off of Summit and experience tells me to know EXACTLY what you want prior to ordering parts off them .....and they got allota springs.
350Z
350Z
evilstuie
01-09-2020 08:29 PM
LT1Formula
20
11-14-2015 12:02 AM
