Quicky question... (valve seals)
I am going to be doing my valve seals this weekend and I was wondering what size compressor I need to use for the air fitting thing. (I dont know the correct name, the thingy that plugs into the spark plug hole and keeps the valves from dropping into the cylinder.) I have a little home compressor, but it probably maxes out at 50 psi. Thanks for any help...
Car: yep
Engine: uhuh
Transmission: sure does
I just use a compression gauge hose (screw in type) and take the valve core out of it.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: 4
Engine: 6
Transmission: 5
It doesn't take much, all it's really doing is keepoing the valve from falling in. If you do one cylinder at a time, and turn the crank so that the piston comes up to TDC of the cylinder you're working on, You won't drop the valve anyway ( at least not past the point of no return!). You'll be OK.
ICON Motorsports
ICON Motorsports
355tpipickup
09-13-2015 11:35 PM
