cant get rid of vapor lock, will a electric fuel pump solve my problem
Old 06-02-2005 | 10:16 PM
camaro03's Avatar
Car: 1982 camaro
Engine: built 355 chevy
Transmission: th 350 w/ 3.73 gears
I am having really bad vapor lock with my fuel line as far as i can get it from my headers, i know nothing about electric fuel pumps, but could i put a external one at the end of the sending unit lines?? or is it possible to put one in the tank on a carbed 82?? any help is appreciated, by the way ive heard of a mech/electrical fuel pump setup on some thirdgens?? any help is appreciated thanks
Russell
Old 06-02-2005 | 10:26 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Yea it's possible to install an in-tank electric "pusher" pump. All carb'd models post-86 got just this, for your exact issue, as you have already heard. You may consider just putting an aftermarket pump such as one that Holley offers (red or blue) and install that somewhere down by the tank.
Have you tried a heat wrap around the fuel lines? There are several different kinds, but the idea is the same. Isolate the wrapped lines from the heat they are subsequentally exposed to.
Frozer!!!
01-19-2024 04:55 PM
92camaroJoe
07-29-2023 07:57 PM
RazorN8
01-07-2022 11:44 AM
Infested
05-22-2018 11:56 PM
92camaroJoe
08-13-2015 06:07 AM
Quick Reply: cant get rid of vapor lock, will a electric fuel pump solve my problem
