What kind of times can I expect friday night?
Car: 4 Mopars total
Engine: Pentastar power
Transmission: T/F and New Process
Axle/Gears: Three 8 3/4's & one 9 1/4
Im going to race my 83 T/A. As all of you know, it has a stock LG4 (blah), automatic, and 3.73 gears. The only thing I did was the gears, punched out the cat, and put an open element air cleaner on it. It only has 70,000 miles on it so it runs pretty good...i guess. Any ideas on what she'll turn????
1983 T-top Trans Am. All stock (for now) LG4/auto/3.73 posi. 70,000 original miles. White w/ light blue int.
Car: 99 Formula
Axle/Gears: 342
I'd say mid 15's.
'86 IROC
T-TOPS, TINTED WINDOWS, BRAKE LIGHT BLACKOUTS
GM GOODWRENCH 350
EDELBROCK TES HEADERS
FLOWMASTER, NO CAT
EDELBROCK 600CFM CARB.
KN AIRFILTER
ACCEL HEI DISTRIBUTOR
160* Stat
3:73 Posi
Rebuilt 700R4 vette servo and .500 boost valve
B&M Megashifter, 5" Autometer Tach w/shift lite
Soon to be installed
3" Hooker Aero Chamber
'86 IROC
GM GOODWRENCH 350
FLOWMASTER, NO CAT
KN AIRFILTER
160* Stat
3:73 Posi
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by Mark A Shields:
I'd say mid 15's.
</font>
I'd say mid 15's.
</font>
Check out MyGTA Nicknamed:The Big Red Machine
***AOL IM ClarkeMustGoNow***
Moderator at www.transamgta.com
"What does not kill us only makes us stronger"
Tony
Car: 4 Mopars total
Damn, that good? You guys did read the LG4 part of my post didnt you? That would be awesome if it even broke into the 15's. Like I said, It feels pretty good but its so hard to tell. Oh well, 2 days to go I guess. Any other opinions?
If I were you heres what I would do...Look over the tech articles and check out the mods you can do to your carb system. From what I hear they are pretty easy to work with. Print out everything, and grab a timing light and all tools needed to do the carb mods. Then when you go to the track you will be able to play with your timing and carb to get it to run best. At least you will know for sure if what you are doing is making your car faster or otherwise. I would expect high to mid 15's with the 3.73s but who knows what you can do if everything is running well. Good luck at the track.
peace
peace
novaderrik
08-10-2015 12:44 PM
