95 subrau Please tell me what you think is causeing this, thanks
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Every once in a while when you come to a stop the car will idle way done and stumble a little and then re gain it self, if you put it in netrual during this time it stop right away, now if I manully shift thought the gears it will go to red line in first and second with out missing a beat, but when itgets to 3rd it will sputter every once ina while,? Could the tranny be slipping a little? the motr runs smooth and it does not seem like a ingiton miss. The car is a 4 speed auto. Thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Check your IAC, TPS and min Air, if any of those are off that can cause the idle issue, not sure why it would crap in 3rd.
1989 Trans Am GTA, 5.7L TPI, TH700-R4, T-Tops, dual cats, 9-bolt rear, 3.27, Dynomax muffler, K&N
1992 Camaro RS, 5.0L TBI, T-5, T-Tops, 3.08, L69 Dual Snorkel, K&N - Sold
Theme song for my GTA Cake - The Distance
HoosierinWA
10-07-2015 10:15 AM
