215-70-15 Tires fit on stock 15" Z28 mags?
I need to put some tires on my spare set of mags, and my dad is getting the tires on his mini-van changed. They are 215-70-15. Mine have almost NO tread left, and all these will be used for is storing the car in the winter and when I take my car to a shop, so light driving.
The tires on the mags right now are 215-60-15 (I think). I'm just wondering whether I'll be rubbing or not with the 215-70-15 on there? This is an ideal situation because all I have to pay is mounting/balancing then for the 4 tires.
Trevor
87 Z28 - LG4 - 305
Hedman Headers, Y-Pipe, Dynomax Exhaust, K&N Open Air Filter
Trevor
87 Z28 - LG4 - 305
Car: 82 camaro SC
Stock size is usually about 215/65R15's. Those tires will work just fine, but be a little bit taller.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
82camaro
That's good news. I'm going to grab 2 sets then since they're free.
Trevor
87 Z28 - LG4 - 305
http://immortaltk.tripod.com/z.html
Trevor
87 Z28 - LG4 - 305
1992rs/ss
16
01-28-2016 09:58 PM
