fuel pump or relay? when...
Car: 1989 IROC-Z
Engine: 5.7-/-350
it's been sitting 4 like a year now and it's in great condtion...I don't kno where the fuel pump relay is...I honestley need pics? PLZ! I figure i'll replace that and if thats not it i'll do the deed and replace the pump...but help me! help me!lol find this dang thing...Yes I did read the other threads and no it didn't help. Um...what could it all be gas/elec. wise...cause dam...thanks...more posts the better, I plan on doin some work on that beast 2day! 1989/red/t-tops/5.7/auto/350/same engine...help!
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Not sure about the 88 setup, but on most for several years, it should be on the drivers side firewall on a bracket with possibly 2 other relays. If there is 3 relays there, it should be the middle one. At least it is on my 86 305 tpi. You could also try and find a wiring diagram or a repair manual with a componet locator. Good luck!
Car: 1989 IROC-Z
Engine: 5.7-/-350
If it's not the fuel pump relay or fuel pump. What else is there? Any switchs, fuses or other relays I need 2 check that have 2 do w/ the fuel pump??? Really help me out on where 2 find them if there is more 2 check cause its a bitch under that hood...thanks!
relays
I was curious about the same thing on my 88 Iroc. I was playing with those relays by the brake booster, there are 3 of them. Two of them are the power and burn off relays for the maf, the other is supposed to be the fuel pump relay, funny thing is,,,,,when I have them all unplugged the fuel pump still runs normal I posted about this once before and no one really had an answer for me. Still not sure where that sucker is Hopefully your question will be answered and help both of us.
Larry.
Larry.
