How to choose the correct spark plug? Some other questions also.
Old 08-25-2001 | 12:21 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
I seem to have problems finding plugs that work well. Bolth of my 350's camaro and truck have 58cc heads and flat top pistons. Usualy I run either autolite 26's or 666's, they bolth seem to work decent but with a high output coil I should be able to increase the gap more right? Also If I do a compression check and lets say I get 150 on a hole. My old spark plug cleaner has a guage to test the spark plug it compresses air and tests where the spark plug stops producing spark. Ive tested the 26's and 666's gaped at 35 and the spark dwindels at 65 on bolth plugs. The guages red zone is from 0-75 yellow 80-110 green 110-165. I would assume that the green zone is preferable since it is in the same compression range as the cylindar. Is this true? If so why do these spark plugs drop spark so early?
Im really confused "more like this is the first time ive really bothered with it" when it comes to ignition realated stuff. Especialy when the eqqiptment I use to test doesent have instuctions.
Any help would be apreciated.
SSC
Old 08-26-2001 | 03:11 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Anyone? BTT.
Old 08-26-2001 | 04:50 PM
Xenodrgn's Avatar
Standard Delco's are the way to go, run stock gap (.45 I believe) and you'll be fine...
If you run an aftermarket coil you can usually get away with .5, but play with it and run with what works best.
As for your spark dying out at 65PSI... Beats me... if your engines are running good, I'd question the tester. Perhaps someone else can jump in here?
1985 Camaro SC - 2.8L, auto.
http://www.xenodrgn.f2s.com/Frontright.jpg
Old 08-26-2001 | 05:23 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thanks for answer my post Xenodrgn . Mostly Ive seen subjects dealing with spark pushed back and not fully answerd. I checked my tester with my cpmression/leak down tester and its dead on so it could be user problems but I doubt it. It seems to me that I should need a plug that works in the compression area of my engine. Im going to check latter and see what im getting on a couple holes to see for sure. Anyone know of a spark plug part number for high compression engines? Im thinking some of the factory 327's had some beefy compression.
SSC
Old 08-26-2001 | 08:59 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
I think the Delcos have a .35 to .40 stock gap. .45 would be useful for a few extra ponies if you have a complete high performance ignition system, otherwise your rotor will start shorting, or plug wires will turn intermittent, etc. Just a real pain to diagnose so I would stick to a sure spark at .35. I actually run the Bosch platinums, which supposedly never lose their gap, and so far they are great
1986 Camaro Sports Coupe
T-tops, variable wiper, power hatch, rear defrost, third brake light
LG4 305 V8, Hooker Shorty headers, 3" pipe into Walker Quiet Flow dual exhaust
Edelbrock Performer intake, "Damonized" Q-Jet 4bbl, K&N filter, Crane ignition kit
TH700R4 transmission and Derale cooler
Air conditioning, power windows, power door locks, power brakes, power steering, tilt wheel
Kenwood cassette, Pioneer 6x4 component front speakers
Rockford Fosgate 6x9 Punch rear speakers
Z-28 front and rear sway bars
Aluminum slots and Goodyear 225x60R15 Eagle HP tires
243 horsepower and 326 foot pounds of torque at the flywheel
_ _ _ _ _ __ _ _ _ _ _
Yea verily, and he smote the smog heathens from his small block Chevy, even from the air pump to the converter ...
Todd 1:1
Old 08-27-2001 | 11:04 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by Sitting Bull:
</font>
I have an MSD6al and blaster 2 on the camaro hooked up to an one of those funkey relocation caps all msd except for the accel distrbutor itself. The truck has a pre assembeld accel distributor.
I know the camaro qualifies as high performance ignition and the truck is basicly an upgrade from stock.
SSC
1992 Trans Am
05-10-2023 08:19 PM
apo_bailon15
03-28-2016 06:20 AM
evilstuie
02-28-2016 04:33 PM
eightsixseven
08-14-2015 04:09 PM
Quick Reply: How to choose the correct spark plug? Some other questions also.
