3 inch exhaust pipe and 2 1/2 inch muffler
I noticed my muffler has a 2 1/2 inch clamp securing the 3 inch pipe that comes from the cat. Do I have the right muffler inlet size ? Did someone squeeze down the diameter of my pipe to fit into the muffler inlet pipe ? Sould I have 3 inch clamps at the muffler ? Is it normal for the 3 inch pipe to come down to 2 1/2 inches at the ends ?
88 GTA 5.7 TPI Charcoal Grey Bone Stock except for loose muffler which makes it a bit louder than normal.
Sam thing here, the cat outlet pipe is 3-inch comes out into dual 2 1/2 inch pies from the muffler. Seems normal to me, you would be able to see if somebody tried to squeeze the pipe on.
Car: 88 IROC
Mine is like that, too. I had MAF relay problems and a backfire blew out my GM muffler. Had to get a Blowmaster (cheapest). Seemed odd to neck the pipe down like that...
88 IROC with cobbled together (not by me)drivetrain, 86 (?) TPI unit,CE subframe connectors, Edelbrock strut tower brace, polygraphite bushings all around...it handles like a dream, but man is it hard to push!!
<font face="Verdana, Arial" size="2">Originally posted by Bjase:
</font>
</font>
Were both mufflers necked down at the inlet ?
GTA88
<font face="Verdana, Arial" size="2">Originally posted by maksik7:
Sam thing here, the cat outlet pipe is 3-inch comes out into dual 2 1/2 inch pies from the muffler. Seems normal to me, you would be able to see if somebody tried to squeeze the pipe on.</font>
Yeah, but on mine the 3 inch pipe from the cat is tapered down to 2 1/2 inches when it clamps onto the muffler inlet. What is the inlet diameter on your muffler ?
GTA88
morrow
01-13-2024 12:29 PM
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
