Bad Vibes!! Help!
Bad Vibes!! Help!
My '86 Bird has a really bad vibration over 60mph and around 40mph. I tried two driveshafts, both with new u-joints, and the problem is still there.
The vibes are there if it is in neutral, the clutch is in or it is in gear (ie. all the time). To me, this rules out engine problems.
I did swap in a T5, could there be an alignment problem? How would I check for it?
I am at my wits end
Thanks in advance
Dale
1986 FireBird
2.8L MPFI
Gutted Cat, No muffler (Sweet Sound)
Was 700-R4 --> Now T5
[This message has been edited by 86Chicken (edited August 17, 2001).]
I am at my wits end
Thanks in advance
Dale
1986 FireBird
2.8L MPFI
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Balance your tires?
Good, evenly worn tires on your car?
Front end aligned?
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps, MacEwen white-face guages
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Front end aligned?
Performance:
Electronics:
Oh, yeah, I forgot to mention that...
Rear tires are new and balanced. Front are not new but OK. I rotated the tires to see if that was the problem but there was no change.
The front end was aligned about a year ago, but the vibration is there even the car is run up to speed while on blocks.
Dale
Dale
Car: 4
Engine: 6
Transmission: 5
Too easy...
To check for a bent axle, put the rear axle up on jack stands, put the car in gear, and look to see if a wheel wobbles. If it does, swap the left & right, and see if the wobble stays or moves to the other side. Same side = bent axle, moves to other side = bent wheel.
ICON Motorsports
ICON Motorsports
What ABOUT the torque arm????
The vibes started about 1000 miles after the swap. The torque arm is attached using the T5 mount. I do not know how to tell if it is at the correct angle/position or not.
Dale
Dale
Well, I checked to see if the wheels wobbled per RB83L69's instructions and both sides have a little (3/64" +/-) wobble but I can't tell if it is the wheels/tires or axle.
Any other suggestions?? This is driving me nuts.
Thanks,
Dale
Thanks,
Dale
You may have an issue with the pinion angle, or possibly the tailshaft on the T-5. I'll try to find specs on the inclination of the pinion.
I would have better access, but I just spent most of yesterday afternoon and evening reinstalling Win98, configuring the system, and reinstalling most of the applications because of the Sircam.exe email virus infecting my boot sector. Really funny - I was rubbing the slide on a chrome 45ACP just waiting for something to "vent" on...
Later,
Vader
"Get UP - Drop the bombshell!"
Adobe Acrobat Reader
Later,
Vader
vader....sucks huh!! i got a nice one about 5 months ago...my comp is still alittle funky... whadda ya say...we get together and have our selves an "office space" party. you bring the music and ill bring the 9mm for haa haa's ill bring a bat too and amybe an old copier
87 z28 bowtie aluminum 420small block dry sump crower lt. wt. knife edged crank oliver lt wt rods brodix track 1's super ram intake slp 1 3/4 headers accel dfi art carr 700 r4 3.42 gears ssm sub frame/ladder bars.....other parts on the way ,soon to be finished!! couple more weeks!!!
http://people.ne.mediaone.net/gdm
I wondered about the pinion angle when I put in the tranny but forgot about it when everything seemed alright at first.
How do I measure the angle? Can I just do this with a level and a protractor or do I need something more precise?
What is it supposed to be?
If it is wrong, how do I go about fixing it?
Thanks for all the help!!!!
BTW - I know how you feel about cleanng up after a virus (I prefer my 9mm tho. ).
Dale
Dale
dimented24x7
09-17-2015 06:58 AM
