What cams do u use in your 383 TPI's ?
Hey everybody. What cams do you guys use in your 383 TPI buildups ? I'm doing one right one and I just want to get a feel of the cam specs should be like. Thanx
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car !
92 Z28 5.7
Daily driver 383.
Custom comp cam
224/224 567/567 on a 114LS
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.47@129 1.55 60FT. ON MOTOR - ET-STREETs w/MUFFLERS
Custom comp cam
14.1@ 98MPH
OTHER RIDE
I'm getting this cam from a guy, comp cams custom grind, brand new with 230/230 duration and 560/560 lift. Would that be too much of a cam for a TPI 383 ?
92 Z28 5.7
92 Z28 5.7
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I'm running a Comp XE solid roller 236/242 .602/.610 112 lsa. The intake I'm running is a MiniRam. If you plan on using long tube runners I would recommend the LPE 74219. It is probably the most versatile cam out there. The specs are 219/219 .525/.560 lift with 1.6 rockers 112lsa.
D&Z Performance
"Putting Power to the Pavement"
D&Z Performance
Check this site out ...they have combos with the afr heads and dyno charts. I Think the cams displayed in the site would work just as well with the trick flows.
1 Post
Car: 1987 IROC Z28
Engine: 6.0L LQ9 crate engine
Transmission: Performa Built 700R4
Axle/Gears: 3.42 10 bolt, Eaton/Moser
Not a TPI nor daily driver, but the car is on the road. I used a TPIS ZZ9 cam with
212/226 - .483/.520 with 1.5s on a 112LS.
Very smooth running motor till you go high rpm then she screams!! TPIS cams are renowned for their aggressive lobe slopes which open the valves quickly. Runs great even on a carbed motor!!!
Phil87IROC
Blue '87 IROC, 383 Crate Motor, KB pistons, AFR 190 heads, TPIS ZZ-9 cam, Edelbrock RPM intake, 1" TD spacer, Hooker SC/LT headers w/ Mufflex Y-pipe, Edelbrock 750 cfm Carb (#1411), Stock T-5, GM 3.42 gears w/Auburn posi.
Ohio Valley Dragstrip (KY) Trophy Bracket WINNER - 8.39 ET on a 1.82 sec. - 60'. Best MPH = 84.44. Still Tuning Carb!
Red '89 IROC L98, TES w/Flowmaster, 1LE DS, 700R4, T-Tops, K&Ns w/open air boxes, 160 T-stat, Hypertech Chip, gutted MAF & CAT, Jacobs Ign., 53kv coil, MSD wires.
[This message has been edited by Phil87IROC (edited August 18, 2001).]
Phil87IROC
LT1Formula
08-20-2015 09:36 PM
Sanjay
08-12-2015 03:41 PM
