problems with spark plug hitting piston.
so i go to turn the motor over to get it at tdc #1 and i pulled the spark out and the plug electoed is bent
so i pull the rest out and there all bent ...now i have trw pop top pisons i think that there hitting the plug at tdc...i have never ran this motor what do i do? is there a plug that i can buy that will take up for this? pn# please
thanks chris...
![EEK!](https://www.thirdgen.org/forums/images/smilies/eek.gif)
thanks chris...
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
what kind of pistons exactly (part number?)?? Also, what kind of heads and head gasket?? And finally, what kind (part number too) of spark plugs do you have right now?
Car: 1995 Corvette
If I'm not mistaken, those are the wrong plugs for those cylinder heads.. A 5245 has .709" reach, taper seat, and an extended electrode.. Those heads should take a .460" reach, taper seat, standard plug... I think that is your problem... the spark plug is probably threading way too far into the head before it seats, and the extended tip isn't helping you either...
Specs by SparkPlugs.com:
Autolite 5245 - .709" reach, tapered seat, extended tip
Autolite 26 - .460" reach, tapered seat
dude your the man....thank you sooooooooooo much...wow sweet what kind of plugs sould i ask 4 when i go to the parts store..what heat range? a part number would be grate...
thanks chris![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
edit...sweet links..thats all i needed...damm THANK YOU....
thanks chris
Car: 2002 Formula Firebird
Transmission: 4l60e
Get some r43ts , r44ts, or r45ts AC delcos. Only difference is the heat ranges. 45's being the hottest.
The plugs you are using are what my mothers 02 accord v6 takes IIRC. Way to long.
Car: 1987 TA
Engine: 350 stock/twecked
I have had the best luck and performance with NGK v-power race plugs. if not running nitrus use the ur4--they are a raceplug one heat range hotter than stock--go to napa they have a ton of them on hand about 2 bucks a pice just my 2 cents
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The TS plugs should be extended tip. You might just want regular R43T plugs. Also index the plugs so the the ground is at the top of the cylinder away from the piston. I have to index my plugs or the ground gets hit by the piston.
what kind of gap should i run whith the compresstion i have *thinking 10/1/2-1 .....and i have a msd 6al box...also what heat range..i sould get the 43? thanks for all the help
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
so called "race plugs" are actually colder then stock
has to do ith most motors designed for racing have higher cylinder temps then some joe schmo driving around town going put put
the put put car is goign to have less cylinder temps so it's going to need a hotter plug to reach a self cleaning temp
a hotter plug like that in a racing motor is goign to cause issues of detonation, or electrode melting
Transmission: 4l60e
IIRC they recommend a .045'' gap with aftermarket ignitions and .035'' without a performance ignition.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I thought you were supposed to index plugs so that the open face of the electrode was pointing towards the VALVES, not the piston.
Also, if your SBC was 10.5 compression and supposedly 400HP, would you use the Autolite 24 or 25? I think the 24 is slightly colder if I understand their numbering system....
Hopefully the A-24/25 are a little shorter than the AC 43TS/44TS that won't clear my headers.....
evilstuie
02-28-2016 03:33 PM
eightsixseven
08-14-2015 03:09 PM
