Argh..Where can I find a schrader valve that fits the fuel rail?
The standard tire size threads..But it leaks all over the place. I AM NOT paying the $30 Chevy wants for it. I know it's the same size as the A/C retro fit..Where can I find that? Is there a part number? A specific size? I am going crazy looking for it..
I am looking to buy Edelbrock T.E.S. headers with the y-pipe. I am also looking for a 3.42 - 3.55 posi disc rear. cheesy@fred.net is my e-mail, send a letter if you can help!
- Red '88 IROC 305 TPI T-5 w/3.08
- Accel 300+ Ignition
- Accel 300+ Pro Sleeve Plug Wires
- AC Delco Rapid Fire Plugs
- Dual Friction Stage III Centerforce Clutch
- Energy Suspension Transmission Mount
- Flowmaster Force II 3 Chamber Cat Back Exhaust
- Gutted Airboxes
- Hypertech Stage II PROM
- Hypertech Airfoil
- Throttle Body Coolant Bypass
- Best Maryland (40 degrees) E/T 14.686, 60' 2.205, 1/8th mile 9.461, 1/4 mile MPH 93.91
- Best Florida (80 degrees) E/T 14.88, 60' 2.163, 1/8th mile 9.540, 1/4 mile MPH 92.74
- Best 60' 2.163(Florida)
- TPiS AFPR set to 42psi using Accel Fuel Pressure Gauge (Installed after Maryland run)
- Aluminum Driveshaft (Installed after Maryland run)
snap-on makes adapters if that's what you need. check out a catalog or ask a snap-on man.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
I am talking about the actual valve core. The thing with the little pin you push to releave pressure. Is that what you guys are talking about? I wasn't very clear in my original post..
- Gutted Airboxes
- Hypertech Airfoil
R3500
08-17-2015 12:16 PM
