Cold Start Fuel Injector Problems
1 Post
Car: 92 Formula
Engine: 5.7 L
My car will not start, I've taken it to a mechanic and he found it to be the cold start fuel injector. It's stuck in the on position and keeps flooding the engine so it wont start. It'll turn over if you start it with the gas pedal all the way down (to stop the fuel pump). but once the pump kicks on it'll flood it. The mechanic Replaced the injector, with still the same problem. He also disconnected the computer and it stoped the problem so the compuer was replaced to see if it would fix it. Yet it's still having the same problem. So my mechanic bill is getting jacked up, and my car still doesn't work. He's still unsure of whats causing the problem so I figured I'd consult the experts.
I have an 89 Firebird 2.8 V6 TPI
Car: 1985 TA
Engine: L69 305 H.O.
You could have a bad thermo time switch causing the cold start valve to malfunction.
I don't know much about this, but the thermo time switch is in the schematic for the cold start injector.
Car: 91 camaro rs
Engine: 350tpi
The cold start injector is wired to only have power when it is being cranked. If it doesn't stop when it's running it must be a wiring problem (if the injector is good). I would unplug the cold start injector and go from there.
Firechicken86
08-12-2015 10:07 PM
