Distributor Gear Question...
I posted this question once before and did not receive much of a response and I could not find any info in the archives. My problem being when I had my 1991 Formula TPI350 rebuilt and had 1.6 ratio roller tip rockers installed with a COMPUCAM 2032 pn: 104224 and a bronze distr. gear. I have found out that the distr. gear is being chewed up. It has been 8000miles since the rebuild. Does anyone know some or all of the possible reasons for this to take place? I am at a loss and I would like to have an idea of what I am getting into before I pull the motor again.
Car: 88 Firebird WS6
You could also cut a groove .020"x.020" in the lower land of the distributer(There's 2 rings to seal oil pressure near the bottom of the dirstibuter). Make sure this groove faces the cam gear (pass side) when installed. This will force oil the gear.
You must be using a high volume oil pump. Bronze gears don't last very long anyways, but added oil will help.
Why did you put bronze gear on?
Street roller (cast or steel)cams have cast iron gear on them.
The only time you should use bronze gear is if you have ALL steel cam (race only)
'91 Camaro 3.1 t-tops 44k original.
'98 GMC Sonoma excab 4.3 auto 35k.
Also bronze gears are made to wear out faster,this prevents expensive came from wearing out on the gear.
Thanks for the info and the help. I screwed up. I used the wrong gear. I needed the steel gear not the Bronze. She runs sweeeet now that it is all sorted out! Take it easy.
krazydiver
91 Formula 350TPI
krazydiver
91 Formula 350TPI
eightsixseven
08-14-2015 03:09 PM
