Hole in my tire help????????????????????
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
I have a screw in my tire its pretty thick. It went all the way through so when I pull it out it obviously leaks badly. I have one of those tire repair kits from Walmart that has those beef jerky looking sticky strips that you jam in the hole with those tool things they give you. My question is are those repair kits any good? Do they hole up at high speeds and hard turns? Or if its possible can a tire place take the tire off the rim and put a patch on from the inside? How much would that cost and is it safer? or should i just do it my self with that kit?
1987 Iroc 350
GTS headlight/tail light covers
Camaro SS Wheels w/Sumitomo HTR ZII 275 rear, 255's in front
K&N filters
Adjustable Borla cat back
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
To go really F'in fast!!!
Some pics of it at
http://albums.photopoint.com/j/Album...949&Auth=false or (still working on) http://members.cardomain.com/john87iroc
1987 Iroc 350
K&N filters
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Take it to any Discount Tire, Big O or Walmart, whatever you have where you are. Period. I've never had any luck with the "beef jerky" type fixes, and I have never felt it was worth trying on any of my 3rg gens. Is less than a $10 repair worth risking your car?
Chris G
91 TA WS6
Chris G
91 TA WS6
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
<---- benn driving arround liekthat for over a year now with the beef jerky patch.. So far so good and it holds pressure great.
Kat
Kat
Car: 1986 Firebird
Engine: 2.8 V6
My tire shop always patches tires from the inside- yes, it's possible. It costs a few bux more than the "plug" method, but that's the only repair my shop does. Of course so many people have their tires plugged and not patched, and nothing happens... but I feel better with a patch in there.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: 4
Engine: 6
Transmission: 5
DO NOT use a plug on a steel-belted tire. The belts may cut the plug in half internally; when that happens, air pressure will allowed into the area between the belts, and will cause the tire to separate. That is a sure way to ruin a tire.
Alot of tire places will do a free flat repair. Even if it's not free, it's usually not more than $10 or $15 to get it patched. That's a whole lot cheaper than having to replace a tire because it does the Wilderness ATV thing from putting a "string" plug in it.
ICON Motorsports
ICON Motorsports
Transmission: 4L60e
Axle/Gears: 9 bolt
<font face="Verdana, Arial" size="2">Originally posted by RB83L69:
</font>
</font>
1987 Iroc 350
K&N filters
SLP 1 3/4 headers
w/ Air born coating
3" Catco cat
Large tube runners
ported plenum
Holley afpr
FUTURE GOAL:
Some pics of it at
Car: 82 camaro SC
Those plug kits are good if you can't get to a shop right away, or on a worn out tire that isn't worth fixing. Walmart TLE will patch it for 6.50. Done right, a patch is a permanent fix.
Forgot to add that some shops (Walmart), have a patch with a plug built into it. It works excellent for bigger holes.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited July 31, 2001).]
82camaro
355tpipickup
09-13-2015 11:35 PM
84 TA NV
09-06-2015 08:02 PM
Glowsock
09-05-2015 07:48 PM
