sudden loss of power
Car: 1987 Firebird
Engine: D.Remmington 415 Small Block
Axle/Gears: 4.10
when it runs and warms up it would periodiclly lose paower and i had to fight it to keep it running, and woulnd like to move at all, but i would punch it and bring it up to high rpm's and it would clear up a bit, last night it went out completeley and when i opend up the 4 barrels it would act wors that when i was only on 2 barrels. I poppet the hood and rev it manuely it would rev extremely slow and the coil would have a line of purple glow right next to the heat sink. It's an '87 firebird weith a 305 ccrochester and a 700r4 tranney. please help im dieing here.
Car: 1987 Firebird
Axle/Gears: 4.10
Please don't be shy any suggestions would be awsome, nas far as the distributor goes it's all new, cap, rotor, ignition module. and amasingly enough im also starting to diesel when i shut it off periodically and it backfires when i get on it and open up the 4-Barrels. Please im desperate.
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Put your old coil back in and see if it still glows like that....
Car: 1987 Firebird
Axle/Gears: 4.10
Yes it does, but only when i have it at full throttle and it's accelerating through the rpm's. and it has to be dark in order to see it.
theshackle
09-17-2020 09:26 AM
sailtexas186548
08-24-2015 11:11 PM
