Will a valve spring compressor work for a door hinge spring?
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
or vice versa? I got a new door hinge spring and need to put it in. The Roc hasn't had one as long as I've owned it, and I have to race the door when getting out of the car This thing is definitely NOT doable by hand, the spring is VERY strong, I need some type of compressor. The ones I found for GM dealers cost $65 and look like they should cost $10. I planned to get a valve spring compressor in the not so near future anyway, could I use it on this spring? Has anyone else had to do this and if so what did you use? Thanks in advance!
I ROCK
...so you don't have to.
I ROCK
1 Post
Car: yep
Engine: uhuh
Transmission: sure does
All the valve spring compressors I use won't work.
I've used the correct tool and it makes the job real easy...
I would go by a body shop and see if you can borrow their tool or have them throw it in for you for a 12 pack or something.
It only takes a minute.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
and 2 POS commuters...
R.I.P. #3
"He can see air"
1999 NBM Trans Am
1981 corvette
1995 Kawi ZX6R
R.I.P. #3
"He can see air"
Car: '89 GTA
Engine: ZZ6TPI
I know what you are talking about. The compressor you are talking about in mainly for lawnmower engines and it looks just like the GM tool. I think it will work.
89 Transam GTA, 350TPI, auto, 3.27 rear, dual cats, gray.
Magnaflow cat-back,
K&N open element,
Best E.T. 14.63@95mph
Magnaflow cat-back,
K&N open element,
when i work on the hinge spring i do the same thing i did with my kart engines when i rebuilt them. i put the spring in a vice and compress it and then use safety wire to hold it together. i think i used 4 pieces wrapped twice around it and the spun with the safety wire plires. after it's in just cut the wire and pull it out.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 88 Firebird WS6
I did a similar trick with the vice, except I used nylon zip ties to hold it together. Then after I got it in, i just cut the ties and pulled them out.
AkDrifted
08-17-2015 07:45 PM
