Problems with '91 B4C ETs, please help!
I got my '91 B4C running fairly good, or so I thought after I installed new injectors. The problem is, I've been to the track twice and can only muster up a 15.45@90 mph. My friend says that it should at least be in the 14s, which I tend to agree. The previous owner (being the dumba$$ that he is) replaced the original exhaust with a 2 1/2" cat-back Midas special. My friend advised me to replace it with a 3" Cat-back and this would help the situation. I was looking for some more advise on this. Any help would be greatly appreciated. I just did a complete tuneup and set the timing at 8 degrees advanced. Thanks!
1991 B4C Camaro, 305/5-speed, loaded, black, 57k miles.
Does anybody have any experience with G92 305 equipped cars? I'm trying to get this thing running decent. Anybody out there with a '91-'92 Z28 with a 305, 5-speed setup? Thanks!
Sean
'91 B4C Camaro, 305/5 speed, 3.42s, 57k miles, loaded.
Sean
I don't have your answer but I know the guys that do will want to know your 60 and they will want to know if you missed any shifts or if you are new at driving a stick stuff like that. I do know a tune up is the first thing they will suggest.
91 z-28 305 700R4
3.73 gears out back
T-Tops and Black all over.
91 z-28 305 700R4
3.73 gears out back
My 91 ran 15.0@91 stock. Look at my sig for mods & times. Hope that helps a bit.
91 B4C 305 TPI - SOON TO BE 383
TREMEC 5-SP, STOCK 1-BOLT REAREAND w/342 GEARS, K&N, AIRFOIL
EDELBROCK HEADERS, DUAL CAT TO HOMEMADE Y-PIPE & 3.5" SINGLE PIPE W/ FLOWMASTER, CRANK PULLEY, MSD, FUEL PRESS REG, COWL HOOD, WELD WHEELS
14.1@ 98MPH
OTHER RIDE
67 CAMARO - STREET CAR, BIG BLOCK, PUMP GAS
350TH w/ATI 10", 12-BOLT w/373 GEARS
10.94@124.13 ON MOTOR - ET-STREETs w/MUFFLERS
14.1@ 98MPH
OTHER RIDE
Actually I was the one who drove b4c1le's car that night since I can shift alot faster. The car has a fresh tune-up, no missed shifts and the 60 ft times were around 2.3-2.4 but that doesn't concern me as much as the mph. I feel his 305/5spd mph should be 94-96mph. Hell that night he drove my L98 B4C to a 14.34 @ 97.45mph. It was hot that night, around 100-105*. Any other ideas.
1992 L98 DGGM B4C (X-FBI car)
1992 X-CHP B4C, Black and White.
makinemtap,
14.3 is about right for a 350 car. My B4C is a 305/5-speed setup. Most all of my 350/A4 cars ran around 14.3 also. I would be thrilled with a 14.5 or so with the 305.
