Cable to VSS, ECM question
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
So I'm in the process of installing a 140 mph cluster in our T/A. Now I have a question, the pinouts for the 85 cluster have "BUFFER SIGNAL TO ECM" and "GROUND FOR BUFFER TO ECM." I will be installing the buffer box that came from an electronic speedo car. Obviously the brown wire that come from the buffer box provide the signal I need, but there's only 1 brown wire coming from the VSS Buffer box. What is this "GROUND FOR BUFFER" supposed to be hooked into?
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: Cable to VSS, ECM question
Originally posted by 89V6FBIRD
... What is this "GROUND FOR BUFFER" supposed to be hooked into?
The ECM may not have existed when the buffer box was designed into the instrument panel printed circuit board.
The VSS signal is also shared with the cruise control module.
