Lower Air Dams
Car: 86 T/A
Engine: 5.0 TPI
Go to the GM dealer and get a new one. This is one part that they don't rape you on. $20.00 to $40.00, depending on how well they like you.
It is called an air deflector and be aware that there are 3 parts that are called air deflector.
1. Goes in the nose of the car.
2. Is the strip that looks like a spoiler across the width of the front end.
3. Bolts to the bottom of the radiator.
<FONT SIZE="2" COLOR="red">Red 86 T/A</FONT><FONT SIZE="2"> 5.0 TPI</FONT><FONT SIZE="1"> </FONT><FONT SIZE="2">(LB9/WS6)
~HyperTech Cap/Coil/Rotor/AFPR
~Derale Adjustable Fan Switch ~ 170° Stat
~Flow Matched Injectors ~ K & N Air Filter
~Ported Polished Plenum ~ Runners ~ TB
~Polished Wheels ~ Alternator - Fuel Rail
~SLP TB Airfoil ~ Pirelli 245/50/16
~All Else Stock</FONT>
<A HREF="http://www.gmtips.com/3rd-degree/"><FONT SIZE="1" FACE="MS Sans Serif"><IMG SRC="http://www.gmtips.com/3rd-degree/cg/3rd-logo.jpg" WIDTH="100" HEIGHT="80" ALIGN="BOTTOM" BORDER="0"></FONT></A>
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
If its the one that bolts to the bottom of the radiator you can use one off a late 70's Olds Cutlass. We put one on the 83Z. Two of the 6 bolt holes line up and the other 4 are easily drilled out in the plastic spoiler/air dam. The one from the Cutlass is wider and lower than the original. Looks good, works great, cost $5 at the junkyard.
Z's r Best
Z's r Best
1992 Trans Am
05-10-2023 07:19 PM
