Timing new engine
Timing new engine
How far off does your timing have to be to not run? I set the distrib to #1 at TDC. It will start for about 5 to 10sec then die. Vapor shoots out of the carb once in awhile. I'm going to get a timing light tonight but will it help me if I can't even get it running?
If the car won't run then the timing light is useless. Does the car start easily and then die? If it does then I suspect the problem is fuel related... low floats, bad pump, or something like that.
The gas vapor shooting out is normal when it stalls.
