16x8 formula deep dish rims questions
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
hey i like the look of the formula rims and i was wondering if i put them on my car
would they b able to handle a 255/50R16 tire and also would my car b able to handle that wide of a tire all the way around
84TA T-tops L-69 305HO TH-700R4 stock 190hp and 240 ft-lbs.
best E.T. (dont laugh) 15.997 @86.04mph
http://www.geocities.com/K_towngangsta
Guest
Posts: n/a
They come stock with 245's so 255's will fit, but usually you will get a little minor tire rub at full lock up front on the plastic fenderwells no matter if its either one of those. They will fit fine on your 84, just make sure you get a set, the fronts and rears are different offsets.
colton_carlson
03-08-2019 12:21 PM
ambainb
04-25-2016 09:21 PM
kah992
08-19-2015 02:55 PM
