I need a complete bolt kit and gasket kit, recommendations?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
I'm in need of a full gasket set, and I would also like to replace all the bolts with the ARP ones... as they look real good
What do you recommend?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Hmm, since I'm also a turbo Dodge guy, I'm very affraid of Fel-Pro... as they suck for Dodges!
No one has had bad experiences with them on a SBC?
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I pretty much only use Fel Pro for everything.
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
I'll vouch for Fel-Pro as well. Have always has good luck with them.
As far as fasteners go, you really can't go wrong with ARP...might want to look into something like this.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, that's exactly what I was looking for. Is that kit totally complete, or am I going to need other things? Looks like it's all there, but I'm no good at this sorta thing lol
Is there a similar idea for a gasket set? The whole thing at once?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Would I benefit from a more expensive brand? Trick flow makes a gasket set and costs $130! What's the difference?
BTW, not sure if I would need different gaskets/bolts due to my setup, but this is it:
1969 350
Trick Flow Twisted Wedge heads
Holley Stealth Ram
1969 350
Holley Stealth Ram
1 Post
Car: 1989 Corvette
Engine: 350 Tpi
Transmission: ZF 6 speed
Axle/Gears: Dana 44 3,33
I bought fel pro but in my kit they included 3 head gaskets and a egr gasket that didnt fit. I mean i though the v8 only had 2 heads.
Engine: 383 Carb
Transmission: 4L60
Get the right Fel-pro kit for your application and it should have everything you need.
Actually, now that I look, you've got modifications, so it's not likely you're going to find a complete kit from any manufacturer that has exactly the right parts for your combination. You'll probably have to piece one together yourself out of individual gasket sets.
1 Post
Car: 1989 Corvette
Engine: 350 Tpi
Wait, so the Fel-pro kit won't have what I need?
Terrell351
06-13-2021 01:13 PM
ambainb
04-25-2016 09:21 PM
NinjaNife
08-23-2015 11:49 AM
