what will the 1/4 E.T be with new motor
What kind of intake was on the chevelle? What kind are you using? What about exhaust? How much did the chevelle weigh? How much does your car weigh? What altitude did it run that time at? What altitude are you at? What about the trannies?
Car: 89 Formula
<font face="Verdana, Arial" size="2">Originally posted by rezinn:
What kind of intake was on the chevelle? What kind are you using? What about exhaust? How much did the chevelle weigh? How much does your car weigh? What altitude did it run that time at? What altitude are you at? What about the trannies? </font>
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
It will probably run a bit better in your camaro since it's a bit lighter, I think those chevelles are close to 4000+ lbs?
sounds like a stout motor, you should be happy with it.
evilstuie
01-09-2020 08:29 PM
