timing spec - 86 TPI 305
Just finished putting the new oil pressure sending unit in my car. Had to remove the distributor to do it. Top half had become separated enough from the bottom half that it just free spun. Anyway, now I need to set the timing correctly. Distributor went back where it came from and car runs, but I want to be sure. When the new hood went on it after the accident, didn't bother to replace the 'emissions information label' so I don't have the spec. (even the factory manual says 'see emissions information label') Anyway, anyone have the correct timing spec for an 86 305 TPI?? Thanks in advance ...
R.C. Righter
86 Trans Am
R.C. Righter
86 Trans Am
Fast355
12-02-2016 06:33 PM
Sanjay
08-12-2015 03:41 PM
