Where you guys putting your Ignition boxes?
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
I cant find any space where I can put it. Any ideas or pics would be great thanks.
some people put it on the fender, some wedge it on the firewall somewhere. most pics i've seen of them have them on the back of either fender. i dont have a thirdgen right now, but i put mine on my firewall beside the distributor
- 83 Z28-- not a pretty site to look at, 200k miles and im sure it was treated like a rental car every day of its sad life(before i got it).. sold, thank the lord
- 74 Z28-- 383/400, green on black. pretty clean. FOR SALE!!!
Car: 2002 SOM z28
I stuck it under the charcol canister and used really long bolts... There are about 1000 pictures of where people have placed thiers on this board... try a search for it.
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Car: 1986 Firebird
Engine: 2.8 V6
I yanked my coolant reservoir, and put my MSD 6AL box there. I mounted it lengthwise, so you can read the MSD label from the driver's side fender. I made a bracket to go between the lowermost part of the box and the inner wheel well, and bolted the top of the box dirctly to the wheel well.
(edit: Otherwise, the curve of the inner wheel well is too great for the ignition box; the wheel well smacks the center of the box. This way I could get the two "upper" bolt holes laid down directly on the inner fender; and the bracket took up the space between the "lower" bolt holes and the wheel well. The center of the box sits up about 1/2 inch off the curve of the wheelwell.)
I then bought a small coolant recovery tank out of JC Whitney (I've seen them in local stores, too) and wedged it next to my charcoal vapor canister. I should really bolt the thing down one of these days; it's held there with safety wire.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
[This message has been edited by TomP (edited July 17, 2001).]
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
