where is the map sensor located on a 86 ta
Car: 1986 firebird trans am
i cant seem to find the map sensor on my 86 ta hell i cant even find it on the sensor chart on my hood did they have that sensor ?
Car: 92' B4C Camaro
Transmission: G-Force T5
The Map sensors came on the '90 - '92 TPI thirdgens. You more than likely have a MAF sensor.
The MAF came on '85 - '89 TPI thirdgens.
If you have a Card, I have no Idea.
Correct me If I'm wrong here.
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Re: where is the map sensor located on a 86 ta
I'm not sure if it was called a "MAP" sensor those years, but it sure as hell is one.
-- Joe
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
That's where it is on a carb'd car. And, some parts books call it that.
https://www.thirdgen.org/techbb2/sho...hreadid=257699 Called "vac sensor" there.
raymondandretti
Exterior Parts for Sale
09-05-2015 05:02 PM
