Cylinder head rebuild
Car: 1991 Galant VR4
Engine: 2.0L 4G63 Turbo
Transmission: 5sp transaxle/transfer case
I bought a set of old 454 oval port heads.
They have 2.06/1.72 valves and 113cc chambers.
They don't need new valves but I'm going to replace them with some Manley Street Flo valves anyway. My question is what will it cost to have 2.19/1.88 valves put in along with a port and polish to get them flowing nicely again. I'm not talking about any complex CNC machining, just cleaning them up.
look in the yellow pages for machine shops in your area and call and ask the rates, since there is a big differance in differant parts of the country. as far as i can tell around here is about the cheapest i've saw posted but don't recall the price for what you want. the porting if you want something fast and sloppy to just clean up the ports and match the gasket i'd say you're looking at 4 to 5 hours labor.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Watch out, you can easily end up with $500 into those heads. Heck, I dont think you will even get them out of the shop for less than $200, if you have them set up the valves for you.
If you have them do any porting, figure a minimum of $250 will be added to the bill. I did a set of 305 heads (mostly for the learning process) and ended up spending $460 plus 25 hours of my own grinding time. Sure, they flow well now, but I could have done the same thing with off the shelf WP castings.
There is a race shop locally that tells me that they spend up to 40 hours of labor on a custom port & polish job for competition engines. That's including the use of a superflow flowbench though. It can add up fast.
Daniel Burk
View my third-gen hobbyist performance page!
View my reader's ride!
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff., Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
Best of 14.039 at 100.82 MPH in Stanton, MI
New!Full 1LE brake upgrade! Details at website above.
Daniel Burk
Chuck84TA
07-15-2016 09:05 PM
NinjaNife
08-23-2015 11:49 AM
