distributor plate?
distributor plate?
Today while checking and adjusting my timing I realized that it was jumping around a little bit (and yes, the EST was disconnected). The engine seemed to be running fine with the exception of a moderate sputtering every once in a while, but only at low RPMs like accelerating from a stop. I have a new cap and rotor, so I figure that they are okay. I checked to make sure all the plug wires were on tightly onto the plugs and onto the cap. When I pushed down on the cap, I noticed that it wiggled a little bit, so I tried to tighten the two little hold-down screws. It was then that I realized that one of the screws was stripped, or maybe the distributor plate that it screws into is stripped. If it is the plate that is stripped, can I buy just a new plate or do I need a whole new distributor? How hard is it to install a new plate? Would a regular discount auto parts stoe have these or would I have to get it from a dealer?
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Re: distributor plate?
Hotrodboba400
12-10-2019 07:07 PM
amargari
11-10-2015 02:09 PM
sreZ28
10-22-2015 08:21 AM
