K-member oil pan and headers
1 Post
Car: '85 Camaro
Engine: LG4 305
Looking for combinations that work for road racing. I will be installing them on a 40X CI engine with a T-5 trans.
Jason
Jason
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
Originally posted by jrg77
Canton, Milodon , or Moroso?
Hooker, Hedman, or SLP?
PA Racing, AJE, or Pro-Fab? Or did you trim the stock K-member?
Anyone?
Anyone?
Zrated ran hooker supercomps, but said he had the same problem with clearance.
Only two guys i've talked to on here who DOESNT have clearance issues, made their own headers..
-- Joe
1 Post
Car: '85 Camaro
Engine: LG4 305
So I may haveto get some made? Is hat expensive? I don't have a welder, and I would be too new at it to be any good soon enough.
The biggest reason I would consider the tubular k-member is the extra room for the headers. I didn't know that the steering shaft could be an issue also.
Any other parts that can conflict with headers?
Thanks,
Jason
Thanks,
Jason
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
are you running rack and pinion? hooker long tubes and pa racing tubular k member will work with moroso pan #20205 with no problems on stock steering linkage
1 Post
Car: '85 Camaro
Engine: LG4 305
RIght now all of it is stock. I want a road race pan and at least shorty headers. I still need to run cats so I can do the sniffer thing. What I heard is that the pan and headers conflict. If there is a steering rack challenge I'll have to take that into consideration.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Car: 88' IROCZ
Axle/Gears: 2.77
The plastic splash guard is on the oil pan?
Do you happen to remember or have access to the part # for the oil pan?
Jason
Jason
My block is a World Products Motown 350 pre-80 sbc which means it a 2-piece rear main seal non-roller block. The 88' IROC-Z 350 is a 1-piece rear main seal roller block. I don't know if the pan will fit the stock engine.
The Milodon part# is 30908. The Motown block has dip stick bosses on both sides. The pan also has the left-right option, but the website says left because the 55-79 sbc have left side dipsticks.
1 Post
Car: '85 Camaro
Engine: LG4 305
My block is a '76 400. If it fits yours it will probably fit mine. Did you notice any problems with the quality or fit of your pan?
Looking forward to the pictures.
Jason
Jason
Car: 88' IROCZ
Axle/Gears: 2.77
Jason
Jason
My Website
I'll swap some of the pictures, for the others on Friday.
Car: 88' IROCZ
Axle/Gears: 2.77
Looks good, sounds good too. I can read the pride with which you do your work. looking forward to Friday...
Jason
Jason
92projectcamaro
01-18-2016 08:00 AM
