View Poll Results: Which Mini Starter? Jegs or Summit?
Other: PLease Specify!
14.29%
Voters: 7. You may not vote on this poll
Which Mini Starter: JEGS or Summit!?
Car: 1987 GTA :)
Engine: duh! 5.7 TPI
Transmission: Stock
Which would you recommend?
JEGS Mini Starter, Part 555-10001
http://www.jegs.com//cgi-bin/ncommer...58&prmenbr=361
Or the SUMMIT Mini Starter, Part 820323
http://store.summitracing.com/partde...1&autoview=sku
They both look pretty much the same, but JEGS is a little cheaper, and I believe both are the nippodensor starters. If you could include your reason as to why you choose either, that'd be great!Thanks for the input.
1 Post
Car: clapped out 84Z
Engine: 355 efi roller
Transmission: tremec TKO
Stock gear reduction starter off of 90's LT1 vette. You can get them used cheap and can find a replacement at a regular parts store.
1 Post
92-96 LT1 vette starters are all the same. You can get one at a swap meet, ebay, etc. I've used a TCI mini starter on another car for years and it worked great, but it wouldn't fit with my headers in the camaro. The vette one went right in and 2 1/2 years, no problems.
school boy
10-22-2015 11:47 AM
