For those with trickflow heads...spark plug suggestions???
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
what size plugs do i need to fit in the heads? thread size and length?
1 Post
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I use AC FR3LS. They are hard to find so I have also used the Autolite Ones as well. If you do a search You will find many people use the Autolite ones. I think its like 2232 or something like that.
Car: 1991 Z28
Engine: 383
ok so some questions then....im assuming the 5/8" or 13/16" i see is the size of the threads? and what is the difference between the tapered or gasket seat and finally what are the differences between the different reaches???
evilstuie
02-28-2016 03:33 PM
86CamaroDan
09-29-2015 10:08 PM
