383 SB, 7qt oil pan
Car: 83 z28
Engine: 383 SB
Transmission: TH-350
383 SB, 7qt oil pan
does anyone know the correct amount of oil that a 383 with a 7QT oil pan hold?
thanks
heydaddy
thanks
heydaddy
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
wait this is a trick question....lets do the math.......yep 7qts
Car: 83 z28
Engine: 383 SB
i know this seems like a trick question but its not... with my old 305 with a 4Qt pan it held 4.7 Qt's according to mr.lube..... just wanted to know if any one knew the exact number for a 7Qt pan.
thanks
thanks
you need to factor in the oil filter also thats what makes up the differance in the total amount. so if your using a 1/2 quart filter it would be 7.5 quarts. make a reference of where the oil level is on the stick. start car and than recheck oil level and add to reference mark. than take a note of how many quarts it took.
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
My canton pan is 7 qt. I called them for exact info. The say with smaller filter 7 qts total. I would check with pan manufacturer to see if it is pan capacity or total capacity. Canton's is total capacity.
Hotrodboba400
12-10-2019 07:07 PM
