DOH! I nicked a cam bearing
When I installed my new cam in my new block it was pretty hard to turn. After talking with CompCams the suggested I Brillo pad the cam bearings to take the finish off and loosen up the cam. Great. I've done this and the cam has loosened up. In doing this I took the cam in and out of the block numerous times. Anyway on final assembly I realized I nicked one cam bearing and scraped another one. Should I completely panic, strip the block, and have new cam bearings pressed in or leave the cam in which turns pretty well now and think everything is OK?
Many thanks,
Glen Smith
Car: Trans Am
Engine: L69
Well you probally will get alot of mixed answers but personally I dont think it will do anything.... I know a guy who has built engines for 50 years and when I did this to mine he said not to worry, unless is was a rod or main scuff... Kevin
1 Post
Car: 92 Camaro RS
Engine: 305 TBI
Don't worry about it, unless it was a deep scrape all the way across the bearing surface it will be ok.
92 Camaro RS 5.0 5-Speed(Quasar Blue)
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
3.08 Posi-trac
Crane cam
HyperTech Chip
Cool. Neither one is all the way across a bearing. Not even close really. Also neither one is near an oil passage. I think I will leave it like it is.
Thanks,
Glen Smith
i've nicked a few over the years and use my pocket knife to remove the burr and smooth it out. if you use a cam installation tool, or cam handle or whatever they call it will help to keep from nicking the bearings.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
ambainb
04-25-2016 09:21 PM
gixxer92
09-01-2015 04:32 PM
