LOST!!!!!!!
LOST!!!!!!!
Ok i hope this isn't to long. I had a bad ecm. so i changed out the ecm and the prom. (with a stock one). The car started up fine ran for 20 mins or so then, when i shut it off and try to start it again. it was very hard to start and was idleing eradicly. I also recently changed the plugs and wires. could they be affecting the starting when its hot?
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
Not much to go on but I had a hard start problem with my 89 RS ZZ4TPI after it got hot. Turned out I had an injector going to ground when hot, stealing voltage from the others. Plus one was dumping fuel all the time. Maybe have your injectors checked.
Rob P
89RSconvtZZ4TPI Edelbrock Intake
SLP Dual Cold Air Intake 1 5/8" Headers Semi-Siamesed Runners, IROC
suspension, alum shaft. Numerous mods.
92Z28convt5spd (stock)
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Rob P
ZZ3Astro
08-13-2019 12:57 AM
3.8TransAM
09-27-2015 08:37 PM
