How do you remove the turn signal arm?
My cruise control is acting up, it goes to full throttle every time I slide the switch over to the ON position, and I think the switch at the end of the arm might be bad, how do I take it off so I can check it out? Would there be another reason the cruise would do this? Thanks
92 Camaro RS 5.0 5-Speed
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
14" open air cleaner
1998 Dodge Ram SS/T
L98 Alu. Heads
SLP coated headers
Dynomax cat-back
1998 Dodge Ram SS/T
Fronzizzle
03-18-2019 08:29 PM
