Crankshaft Removal
Crankshaft Removal
What is the bast way to go about removing the crankshaft, the pistons and the rods? Should I take the rod ends off and take the crank off, and then take the pistons out the bottom? That's what seems most reasonable.
Car: 4
Engine: 6
Transmission: 5
The pistons won't come out the bottom. If you want to remove them, the heads will need to come off first.
ICON Motorsports
ICON Motorsports
Car: 4
Engine: 6
Transmission: 5
Pretty much, yeah. Don't push on the rod bolts though, push on the rods themselves, with a piece of wood or something like that, that won't damage the bearing bore of the rods. Make sure they don't hit the cylinder walls on their way out.
ICON Motorsports
ICON Motorsports
How long have the pistons been in the engine? You may need to take care of some ridges on the top of the cylinders if you dont want to damage the rings. You could put a piece of rubber hose over the rod bolts so you cant really damage the crank as well, and use a hammer handle or something similar to push the piston out the top.
Hotrodboba400
12-10-2019 07:07 PM
