How to unbolt AC Compressor?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Step 1) Remove belt and unhook electrical connectors.
Step 2) Remove mounting bolts.
Step 3) Remove compressor.
How much detail do you need?
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I'm assuming you haven't taken any hoses or lines loose yet.
Is there any refrigerant left in the system?
If there is you don't want to mess around with it. Go get it recovered first. You don't want to breath that stuff, and it can cause frost burns.
Then you can do whatever you want with the parts you are taking off.
2012sergen11
10-13-2015 07:38 PM
