distributor hold down bolt stuck
Car: 89 Formula
Engine: 305 L03
I was going to advance the timing on my car but I cant get the hold down bolt out. I had a Checker auto parts distributor wrench and I snapped it in half!
Does any one have a proven method for removing a seized hold down bolt?
Car: 96 Silverado/99 Suburban
Engine: 700 cubic inches of 'Muican Awesome
Transmission: 4L80/4L60
Axle/Gears: Chunky/Clunky
Get a Craftsman dizzy wrench and get a breaker bar with some leverage. No bolt can withstand a lil' bit of man-power
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
go to napa, i got a forged distributor wrech from them after i bent a autozone one in half, just twisted it, and it broke right off. But yea, forged wrench + breaker bar = solution
-chillen
-chillen
1 Post
Car: 1991 Chevy Camaro
Engine: 305 TBI
Spray some penetrating oil (PB Blaster or similar) on the bolt and let it set for a while, and then try another distributor wrench on it.
Car: 89 Formula
Engine: 305 L03
Well i just got it to turn. It took a 6 point u joint socket with a 12" ratchet.
I think i was the first person to ever adjust the timing on this car . I advanced it 4 degrees and it seems to run better, but I cant tell for sure because it pouring rain out
Car: 1986 Firebird
Engine: 2.8 V6
That's exactly the tool I always use... I tried a dist wrench once on my v6 and felt like a moron trying to line it up with the bolt- since then, as long as a regular socket will fit back there, I use a ratchet/extension/swivel/socket combination.
But that's just me
But that's just me
1 Post
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
I remember that stupid bolt. *** I hated it, I was like Doward when I got that damn thing out holding the distributor like I pulled excalibur from the stone.
WHat I did, is when to sears and got a crescent wrench piece called a crow's foot. That sucker did the job.
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
I find turning the bolt in the proper direction always works better than the converse...
I have a two-piece distributor wrench (Craftsman, I think), 1/2" boxed on one end and 9/16" boxed on the other, with a 3/8" drive couplier in the middle. If needed, I can pull off the un-used end and attach a ratchet. I've only had to do it a couple of times.
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I just put a stud in the manifold before I installed it, and use a nut to hold the clamp down. I've never had problems just using a regular 9/16 wrench on it before.
