Smoke on Sartup????What is it????
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Recently when my car has been sitting for a few hours or over night it smokes on startup. I have a 1990 RS 305 TBI. The smoke is white with a blue tint (oil burning I think). When the car is warm it doens't smoke at all. My engine is as fresh as can be and only has 28,000 original miles on it. What could this be? Here are my mods
- 3" Hooker Cat-Back
- 14X3 Open element w/K&N with haf inch TBI spacer(turboCity)
- MSD coil, cap, rotor, wires
- Bosche 4+ Patinum plugs
If the car has been stored at all... which i assume it was due to the low mileage then your valve seals have probably dried and cracked.... it is a common problem with these cars and nothing serious... A shop will replace them for about 200. the parts cost 5 bucks.. Mine has been like this for a year now without any real trouble from it except the puff of blue at startup
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Mike
That is a chevy trademark! The valve seals dry/wear out, causing a minute amount of oil to seep into the combustion chambers when the car has not been run in a while-like overnight. I purchased my '86 Z28 new and it started doing this with 30,xxx miles on it, it now has 152,000 and still runs strong. Don't worry about it and keep driving it!
I agree with Blackzee, "Chevy trademark" I had a 99 s10. less than 100 miles on it... it did that too.. nothing to worry about...
92 Camaro 305 TBI Automatic
2.5 high flow cat
2.5 pipes
3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
Future mods.
Headers
O.E.
any other advise on getting to 300+ HP would be appreciated. Thanks
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Custom box
Rockford 1 farad cap
Rockford 800x2 Amp
4gauge wire kit
2.5 high flow cat
2.5 pipes
3.5in tip
shift kit
Future mods.
Headers
O.E.
Custom box
Rockford 800x2 Amp
4gauge wire kit
Car: 4
Engine: 6
Transmission: 5
Totally normal behavior for one of these engines. It's caused by the valve guide seals leaking oil down the valve stems, where the intake vacuum can suck it into the motor. Think of it as the factory's way of assuring that the valve stems and guides get fresh lubricant occasionally.
ICON Motorsports
[This message has been edited by RB83L69 (edited June 29, 2001).]
ICON Motorsports
Don't even bother trying to fix it. They wear out so fast if you fix it you'll be puffing smoke again on startup so soon you'll forget you even had it fixed. The 305's are especially notorious.
1987 Camaro Sport Coupe LG4
700R4 with 2.73 open rear
Hypertech chip, 180* stat
L69 Dual snorkel air cleaner with K&N air filter
CK rods with B hanger
Hooker catback
Pioneer DEH-P4000, Pioneer speakers front/back
Hooker catback
Chevy's way of finding out how many of their engines made it into ford's
1989 GTA 350 TPI - T-tops, dual cats, 9-Bolt aussie 3.27
1992 RS 305 TBI - T-tops, T-5, 3.08 - Sold
